With the Indy-1 and SR head external oil kit if used you can tap the inside of the brass fittings for Holly jets and use .052 to .075 jet sizes to restrict the oil.HS and other rockers that use the needle rollers on the shafts tend to bleed more oil.
In my opinion, this is the best, easiest and simplest solution. Been doing it like this for a long time, always works, and is easy to adjust to your liking....
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
