Are the idle air bleed only for idle or do they effect the tip in also??
They change the amount of air being sucked in through
them... if they are small it pulls more fuel from
the jet... so it can change tip in.... do those have
all the same stuff as a regular carb like pump cams
and squirters... can be the squirters to small or when
they start... does it idle nice.. because a lean idle
can also cause that
Yes,they have pump cams & shooters. I had gone to a smaller idle air to try and correct an intermittent stumble on cruze mode tip in.
