Quote: Are the idle air bleed only for idle or do they effect the tip in also??
They change the amount of air being sucked in through them... if they are small it pulls more fuel from the jet... so it can change tip in.... do those have all the same stuff as a regular carb like pump cams and squirters... can be the squirters to small or when they start... does it idle nice.. because a lean idle can also cause that
