I believe it is a Mopar Performance block. Because the rotating assembly is a 440, the torque converter was ordered to reflect that.
There's your issue...
A one-piece shim is only going to move the starter body out away from the flywheel...
If you know for certain that the alignment at the block is true, I'd next go for a measurement to see what kind of depth you need for proper engagement at the ring gear...
Might be tricky...
(Give Wes a call at Mancini Racing...
He's been around MP for a while...
Run yer issue by him and see if he's heard anything)...
OK, I'm trying to understand this..... When it comes to the relationship of the tranny, converter, starter, everything is 440.. No different than what I had before other than a block with hemi-heads on it.... I didn't figure the casting of the blocks in that area were any different from a 440 to a 426 Hemi block.. I'll call Powermaster and Mancini tomorrow or Wed..
Thanks everyone....... ![](/ubbthreads/images/graemlins/thumbs.gif)
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
