NOW I need to figure out why my beep beep horn is not working..installed a brand new one..nothing..
Pull horn button. Ensure that wire that you see is connected at tab at the top. And then pull(lightly please) on wire to ensure that is properly connected to horn slip ring.
If not connected at that end, then the fix gets a bit more complicated and expensive. You can guess how it is that I know this.
Could also be relay as noted, or the horn grounding wire at the connector where it enters into the steering column.
