On engine side of firewall, try shooting a shot of WD 40 up into the steering column/shaft. The straw attachment on the WD 40 can makes this a bit easier.
Simpler to try this first before pulling steering wheel to lube upper bearing.
The object of trying WD 40 from the engine side is not to lube upper bearing. A squeak can develop at the lower end if the steering shaft,,,the noise then is carried up the column and gives the appearance of an upper bearing problem.
