On engine side of firewall, try shooting a shot of WD 40 up into the steering column/shaft. The straw attachment on the WD 40 can makes this a bit easier.
Simpler to try this first before pulling steering wheel to lube upper bearing.
The object of trying WD 40 from the engine side is not to lube upper bearing. A squeak can develop at the lower end if the steering shaft,,,the noise then is carried up the column and gives the appearance of an upper bearing problem.
I was afraid to squirt anything anywhere just because of the wiring inside..Dont want to cause addition issues or a meltdown.. Thanks for the info guys!! ![](/ubbthreads/images/graemlins/bow.gif)
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
