On my 92, that I had in 93, so the truck was nearly new, it also had the "Dodge lean" I was going to lower the front a little, I cut one full coil from the left side, and 1 and 1/2 from the right.
Took me a while to figure out what I needed to do, at first I just swapped springs from side to side, still leaned left.
So I cut another 1/2 coil from the right, and viola, sat level, and stayed that way. Also de arched the rear springs.
Several years later, ran into the then current owner, he was using it for a used furniture biz, pulling a trailer.
Said he liked the truck, but some body had lowered it, and he wished they hadn't. So I told him I did it.
It was still sitting level tho, just at this height.
Sorry for the bad pic.
