Greg
I would like to think that there's enough valving because i dont want to send them back to the US.
Don
No transbrake, i just flash it from around 2500.
I might look into buying that. Thanks for the remark, the car may look good from that far away but it's getting scruffy up close, i will try and get it painted in the next year. The track is one of the best in europe.
Monte
Please dont take this wrong but you suggest starting at 3/4 from full tight which would indicate around 10, then suggest not to loosen my car up, when on the vid i had the ext 24 from full soft.
I have softened the ext to see what happens next time out but comp is about the same.
Thanks for the advice, please add to this as it helps me to understand what affect these changes make.
Mick
