4 & 1/2 grinder with .040 to .060 cut-off wheel. Very easy to use and control. The only down-side is that the wheels can get used up quickly on 1/8 inch thick wall frame material. However, you probably won't be cutting very much in total length anyway.
- EM
I'll second that. My favorite cutting tool is the 4 1/2" grinder with the thin cut off wheels.
