RapidRobert is right, that is a ported vacuum switch. It opens up internally as it gets warm but vacuum is supplied from a hose to the switch. It has no internal vacuum of its own.
You really need to sort out if this is carb or electrical related. Since you have replaced the rest of the electrical system, try taking your Ignition module in to AutoZone and having it tested. Make them test it several times until it gets hot to see if it starts to weaken.
Try spraying some starting fluid in the usual places to check for leaks - around the carb, vacuum hoses, and intake ports. Also, I've had vacuum leaks in the power brake booster do weird things at idle. Try temporarily plugging that hose/port.
-Reggie
tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
