Quote: Are you running vacuum advance on the distributor? If so, disconnect it and plug the carb side connection. Reset the idle speed and see if the fluctuating idle goes away.
disregard the above, I missed your post where you mentioned cylinders not firing.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
