Has anyone ever used a Altenator, or should I say be able to mount one while using a dry sump pump and vacuum pump with a motor plate I cant seem to find a place.
On my Rampage I mounted the alt on the frame rail
(tube chassis) and that opens up area.. on the race
car I ran a dry sump and alt.. I didnt need the vac
pump
That might just work, What about you A/C compressor ???? By the way got front strut/k-member repaired at Jerry Bickels back on track
No A/C on my junk... 2 windows down at 80 mph
