Thanks! How different is the mounting on the Denso? I run a Meziere water pump so I've made my own brackets to fit the stock alternator. Of course those problems would be eliminated if I go with the one CAB recommended. Any difference in power loss? Shame Summit doesn't stock the factory-style one in cast finish.
Here is what I put on my stroker smallblock.
New Denso Alternator
Gone to the dark side with an LS3 powered '57 Chevy 210
