CC Dave - Don't know about the core shift. AndyF did the port match and he used the intake on the dyno for a few pulls.
Ron - Thanks for the pics, I will be sure to keep that in mind when it comes time to bolt up the intake.
Slanty - Hope all is well!
Thoomer - I hope you can get back behind the wheel soon.
Russ - Your cars have always run hard, so not surprised you are running 9.60's with the NSS dodge. I was thinking about the big ez's in case I wanted to step it up down the road. Last minute change to the 295's. Probably for the best.
Bobby WiZE - Thanks for the intake mod tips. I will look into that for sure!
