Anouther idea with the hot head, is it getting enough oil up top to cool the springs and head, any restrictors? Pull valve cover and look for oil splash. Part of oils job is cooling and shaft could be in backward or stopped up. If oil is restricked one other culprit is the cam bearing holes not lined up.
