Quote: Pretty much any 383 has enough wall to go +.060" easy and usually +.100". I'd check elsewhere.
That all depends , one of the mods ... has shrek for his avatar ... did a 383 based stroker on a .060 block , one of the cylinders split because it was too thin.
