8" without a doubt. Especially considering the motor you bought. a "tight" 8" converter that stalls 47-5200 would work well.
Good advice
Probably makes sense to get an 8 inch convertor. That way I only have to do it once , if it works. The more I really look at the amount of driving I will get to do, maybe I shouldn't have to be quite as conservative
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
