Put a set of 032 squirters in it. Adjust the pump arms so you have around 040-050 play before the pumps squirt. This is about the size of 2 playing cards. This will help to keep fuel available to the pumps. If you are braking up to 12-1500 then flat foot it you have already pushed some fuel out of the pumps.
