The stripped out threads on the needle and seat hole are from using a non Holley brand aftermarket carb kit. If you use a/m kits, the needle and seat are 1 thread off on the thread pitch and you eventually end up with a stripped hole. If you are using one that has a brass jamb nut instead of the screw and skinny nut, you are toast. Only use Holley brand parts for you carbs. An exception may be to get them from QFT, Demon.
Carl Kessel
