That repair looks like a brass insert pressed in to repair the float adjuster. My problem is the fuel inlet threads are stripped out where the fuel line fitting mounts on the side.
Worst thing is I just called chicago carb and they said the outboard bowls are not avalable anywhere anymore. I am stuck with either buying a new or used carb. I called holley and I am currently on hold. 40 min wait time estimate....
