It could be used for power steering but not what is recommended by Mopar or anyone else.
A great many threads on this forum are devoted to circumventing what the factory recommends.
Every time this subject is broached the comments are predictable...."don't do it", "it's not formulated the same" but nobody has ever provided proof of damage that can be 100% attributed to using ATF.
John,the only fact that I can attest to is that about 30 yrs ago I put ATF in a new pump on a 65 Monaco.One year later the ATF was almost black and you could get a black film on you finger just by wiping it on the inside of the reservoir.I cleaned everything,put in power steering fluid and and the color never changed after that.
