Rob, can you educate me on what that means. By fat, do you mean rich? By more to it, do you mean we can find more power? If so, is there a sacrifice in driveability?
Thnaks.
Yeah fat is rich - and you are pretty rich from about 4000 rpm up. Those are in the range of most good running turbo cars. You'd make better power closer to 12.5:1 - 13:1 through the rpm range. Its probably in the outboards. Did Jeff play with the carbs much?
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
