that is odd that it goes away, but I too believe I would try the adjusters first.
back off the one that locks up easy and see if this is still repeatable.
I like to take them to the point where I cannot turn the wheel and then back off the adjuster till I can. I try to count the number of pulls I use to back off the adjuster so I can set each wheel to the same place. kind of ocd about that.
