Pull the pump back off and pack it with Vaseline.
That will allow the pump to prime if you don't want to remove your distributor. Unless your pickup is cracked.
Even though a priming rod is the easiest in my opinion.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
