Quote: This is how member DAVENC mounted his second muffler in the above reference. If is a Magnaflow 7x14 piece. I will be using this idea when I change my exhaust system this Summer.
I don't think I could wedge in the 7" mufflers beside my tank comfortably but I could do the 4" ones for sure.
If I do add these, I am assuming the longer (12" vs 22") the better or not? Also, where would you want to place them to get the best drone elimination? In other words, close as possible to the Flowmasters or closer to the tips?
I want to make sure I do this right and don't shred my exhaust system playing around with this.
