Can simply adding the glasspack type mufflers behind the Flowmasters really quiet it down that much? I am alright with trying simply adding the glasspacks but I am wondering if I am not happy and then have to take it in again to swap the Flowmasters out, if I should just do everything at once?
Just me I'd cut the tailpipes alongside the rear leafs & add the glasspacks which you could easily do with some hangers & you'd be up & running in no time with no labor charges & you'd quickly know if that is going to take care of things
