Front wheel drive cars are hard to hook.My 3.5L 5 speed Altima just blows the front tires off and then goes into wheel hop if I leave above 3500 rpm.The key is getting it to launch.Try slipping the clutch a little and playing with the air pressure to get it to hook.If you don't get it in the 60ft you wont make 13's.
