fastest would be to jump across the ballast with a jumper wire & see if a plug wire is sparking to ground as a helper turns the ign key. If good to that point then maybe the P phasing changed the timing to where it wont start (I'm doubltful) or much more likely the new style gap in the dist ain't right. Keep us updated
