Is there pro's and con's to getting the car certified?
Pro's; it allows you to run the car for 3 yesrs with a NHRA licensed driver, aftermarket axles, certified harmonic balancer, trans shield ,heather tethers, and window net. Cons: It's $150 you don't need to spend if you go 10.0 or slower. You also don't need to spend the $350-$400 to get a NHRA license (every 2 years) either. Doug
I will never complain about my SCCA dues again.......
Dave Dusterberg 1979 Aspen R/T (soon to be #19 CAM/T) 2002 Ram 1500 SLT 2005 Magnum R/T 2005 Mustang GT SCCA CAM/C #19
