Re: NHRA inspection
[Re: pittsburghracer]
#1603439
04/05/14 05:10 PM
04/05/14 05:10 PM
Posts: 7,065 Indiana
maxie
Indiana
Sweet Ride, How fast is it
It's not the road runner in the picture, it is a 72 dodge demon we built last year.
433 hemi 11 to 1 compression 600/600 248 at 50 solid roller dick landy roller rockers diamond pistons with 990 tool steel pins manly I beam rods a and a transmission cross ram with two 770 holleys a and a 727 with a 3800 converter dana 60 with 4.10's
all steel car weighing in at 3700 lbs
Cheese and rise is that car FAT (3700) Don't you HEMI guys know how to build a light car.
The weight is with me in it (185 lbs) and a full tank of fuel
so without me the car is 3515. changing to the mono leafs should take 40-50 pounds off of it.
The car is all steel with full interior. Heavy dana, roll cage, 4 wheel disc, frame tied, full 3 inch exhaust, normal gas tank, iron heads on the motor. The intake weighs 22 pounds
