I am running the 360-2 also but I am using the ARP head bolts instead of the studs. I have had no issues so far.I am also oiling through the push rods.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
