As far as the dash goes my Kenwood is installed in a 70 which as previously stated is different than the 68-9 models. Everything is typically the same with the exception of the finishes on the face plates. Mine had the stock pebble finish on everything. I removed those and fabricated all of those panels from aluminum. The cage installed into the aluminum and then I fabricated a bracket on the passenger side at the back of the radio to hold everything in. I did lower the opening in the aluminum a small amount to allow enough room for the radio face plate to flip open. I covered everything with a carbon fiber vinyl when finished.
Lets be kleer..
A 70 Satellite has the same dash and radio plate as a 68/69 RoadRunner. However... a 70 RoadRunner has a ralley dash like the 68/69/70 Charger and 68/69/70 Super Bee. So the radio mounting plates for a 68/69 RoadRunner are quite different in size/fit/finish than a 70 RoadRunner. Also some ralley dashes had a wood grain finish, I think the GTX did...
Just my $0.05...
