As far as the dash goes my Kenwood is installed in a 70 which as previously stated is different than the 68-9 models. Everything is typically the same with the exception of the finishes on the face plates. Mine had the stock pebble finish on everything. I removed those and fabricated all of those panels from aluminum. The cage installed into the aluminum and then I fabricated a bracket on the passenger side at the back of the radio to hold everything in. I did lower the opening in the aluminum a small amount to allow enough room for the radio face plate to flip open. I covered everything with a carbon fiber vinyl when finished.
