Hey, before I moved, I made a friend a deal on some afermarket axles,and a 8&3/4 housing (wide) to cut, which I NEVER actually checked.
They were obviously aftermarket, with the long straight splines, no neck down,supposedly stock A body width.They came "loose" in the housing with my 68 FB,His #s for what he was doing with his '37 Ford PU
(a 30+ year project,moved from NY to HI on a pallet)
suggested that he could use an A body setup.
Just talked to him t'other day and he was a little bent, as he said the axles were too short?
I found this interesting as he had no stock A housing to try them in???!!!
So what is the outside flange to axle tip measurement on A body L&R axles?
Like to clear this up.He said he and the axle shortening guy 'made it work'.
Thanks,Case
