Bypassing a ballast on the stock system jumps the juice up to 150 percent or there abouts of what it is designed to handle long term. The start circuit has no ballast so it will spark at low voltage in the cold with a weak battery.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
