Have you looked at what the auto manufacturers recommend for power steering??? Yep ATF!!!
Not all recommend ATF for power steering fluid and if you use the wrong fluid you will have issues. Seal compatibility usually.
If your system is designed to use ATF, then use it. If it is designed to use something else you'd be foolish to use ATF.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
