We usually add a qt of 30w non-detergent oil to type F fluid in our trans. Have also used hydraulic oil with some success. Tranny fluid is a poor lubricant and the motor oil helps lube the bushings.
Free advice and worth every penny... Factory trained Slinky rewinder.........
