Re: Engine oil - does it go 'bad' after 6 months; a year?
[Re: astjp2]
#1579725
02/17/14 05:33 PM
02/17/14 05:33 PM
Posts: 22,781 Bitopia
jcc
If you can't dazzle em with diamonds..
Bitopia
Now to rile up the arm chair quarterbacks, the facts by Shell oil engineers state that the oil gets acids in it when it sits after being ran. This occurs when the by produces of combustion and the moisture mixes within the crank case is converted to acids and they will start to eat away at different parts of the engine. 6 months on an oil change helps prevent this on an engine that is occasionally driven. The only way to prevent this is to get the oil temps up to 140* F for an hour to evaporate the moisture each time you run the engine.
Also oil does have a problem after it sits, when the manufacturers put the additives in, they do it at specified temperatures, typically they can begin to fall out of suspension within the oil after 4 years. It may not always happen in 4 years but manufactures have tested and proven it WONT in the first 4 years. Only testing can demonstrate whether they have or not. For the cost of a case of oil, I will use only fresh. Tim
So if the "additives" settle out, it would seem they could also be just as easily re mixed, with little harm, maybe just shake you motor thoroughly before starting after sitting.
No matter where the additives are, when you pour the oil into your motor the additives are going with the motor oil and they will mix just fine if it is even a concern. lol
Uhmmm NO they wont. But all of the chemists on here would know that...that's like saying that if you soak your cooked bacon in bacon grease, the grease will go back into the bacon...when you put it back into the fridge. Do what you want, you will anyways, but I do know that it is an FAA violation if you put expired oil in an airplane, there was an airline who flew piston powered airplanes had several engine failures because they were using 15 year old oil. Shell tested it and found that the additives (detergents) separated causing bearing failures.
So there had to be a time based chemical reaction taking place, in the container, if the additives would not remix. And if for some reason one did not include the settled out additives when dispensing the older oil, I could see a problem. And I would think aircraft, like cars, are constantly being advised to use updated "SN"? type oils, and a 15 year old oil would not be current, just from a standards basis, forgetting age.
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
