I ran 93 w/ 6psi of boost, no cooler and no Meth/H2O, however that was a 9:1 cast psiton motor and I left a lot on the table. I did have an MSD boost retard that dropped the timing 1-3* per lb of boost. I like using that instead of locking in in at 22*. I run the Snow kit on this car (N/A 440-6) and it works. I use regular washer fluid but you can buy the stuff from Snow direct. I guess you could always add alcohol to the store bought. I'd try E85 but I have no idea where a station is that sells it and unless you have a few close it could become a PITA. Whatever you do make sure you are getting enough fuel in DAMHIK.
