Hello all,
I've been playing around with numbers and researching for quite some time, so I figured I'd see what you all thought.
The engine in question is a low deck 470 big block stroker with a 10:1 static compression ratio and stealth aluminum heads.
With the implementation of a methanol injection system such as a Snow Performance kit that utilizes a 50/50 water methanol mixture, would 6 lbs of boost be attainable on 91 octane pump gas without detonation issues?
1971 Dodge Charger SE 470/727/3.91 Suregrip 2016 Dodge Challenger Hellcat, 6-speed 1980 Pontiac Trans Am, Y84, WS6 2002 Ram 2500 Cummins/6-speed/2WD/QC 1971 Ford F-350 Ranger
