Quote: OK, sorry for the delayed response ( I only have online access at work).. I am getting old and and its been a long time since I assembled the engine..
Johns pic of the bracket that bolts to the very back intake bolt is correct.. I must of been thinking of the throttle cable bolting to this bracket.. thanks for all of the help on here, if I want to use the aluminum intake I have I will use one of Andy's brackets.
You don't need that bracket the factory one will work w/ almost every intake on the market.
