No, it was an actual puke tank that would eventually overflow into the radiatior and gum it up.
98-2002 24 valve only. If you read the owners manual that bottle was to be emptied at each oil change.
Even emptying it at every oil change, they still make a mess. The dealership eliminated mine and everything is a lot cleaner under the hood since then. It now just has a hose going straight down and zip tied as described above.
I took that nasty little bottle off and ran a new line to a catch can...like the one you use for a vacuum pump on a race car. Works good.
