I went to my local circle track supply store and picked up the heim ..
I got mine from Speedway Motors..they had a really nice selection. (Used them for all the ends I got to use on my adjustable sway bar end links as well)
And think mine was a 5/16 or 3/8? Would have to get under the dash and measure it, but the push rod on mine might be a different diameter than that wilwood one anyways..
I run ran a die over the rod and went with that size. (luckily it happened to be a handy outside diameter for the die as it was as well)
Yes, dont quote me on the size of the heim, the rod that comes with the Wilwood will determine that. It may be a 5/16x1/2".
Mopar to the bone!!!
