One reason I found that thermostat gaskets leak is either unstalled while too cold lower then 50 degree's or too damp Best bet is install as described flat housing and clean and make sure you let the silicone set up or use a heat gun/ hairdryer on it for minute or two. I do not have any trouble at all with them any more after learning the hard way how not to install.
