Quote: The factory put millions of thermostat housings on millions of water pumps/intake with nothing more than a paper gasket. Either your housing is junk or the mating surface on the water pump/intake is messed up.
Bullseye...
Got 20+ years on an OEM thermostat housing, over an OEM pump housing, with a paper gasket...
