Quote: 9.20 deck. I like that set up! Did you make the motor plate. Is the motor plate the same space out as the stock timing case cover?
I can't speak for Andy, but I don't think his set up works for short deck blocks as the upper water pump hole is in a different location. If you are changing from a timing cover set up to a jesel belt drive you will need some special spacers to offset the motor plate the specific difference between the two. I have been thru this so it is something I an very familiar with.
