Quote: Look closely & you can see where we kicked the door bars around the door panel pad.
I don't have the x bar just side but if you're allowed to bend then that's what I'll do. I don't want to remove the door panels because then what would be done with the back ones and this is a street strip car and don't want a tin car.
