Again wires look clean, connections were all cleaned up and scuffed. Still the same issue. Though the car breifly had the buzzer going and dome brighter, radio still was not coming on BUT the car started with no hesitation on the first turn! Aaaand then after it warmed up it ran rougher. When put into gear, it stalled, dome light went very dim as well as the headlights. It took a couple turns, but I was able to restart the car. This time in gear, my Stock everything slant six sounded like it was cammed up or playing the entrance to "Hot For Teacher". When I tried giving it more gas, it sounded like I was deflating a pinched baloon!!! The car was running smoother just moments ago!!!... Am I not getting proper spark ? Coil, cap, rotor, wires, plugs, are all 3,000miles old. I've converted my original wiring harness to properly power a stock electronic ignition set up. And I tripled checked all of my spliced together wires to make sure they are secure
