Well said Dwayne!!
I have told people for years, call a cam company and ask them what would work best,then call them a week later and you may get a totally different suggestion . I tested a couple others that were not part of the article,but what I thought would work better did.
Another funny story from that whole deal was when I asked for a camshaft for a 421 inch small block and was given a part number for the biggest flat tappet grind in the catalog,for a big block. When I told the guy that was wrong he gave me the part number for the biggest small block grind which had very different specs.
Hughes and Howard's were the two that actually asked for flow numbers,along with several other things that I would consider.
Keith
